just like it says.. I tray to work the bugs out in the driveway with the muffs on but some times it wont shutoff. Start the motor let it run at idle for five or so minutes (idle little ruff but ok) when its warmed up and I give it some throttle it slowly climbs in rpm but not like it should. If i give it full throttle then back down rpms stay at high rpms and wont back down..can take the key out still runs, can pull the saftey shutoff still runs, can pull the spark plug boots still runs, turn the key to the on position and it shuts down.....whats up with that? also I notices that there seems to be a bit of fuel comming out of the carbs and dripping into the lower part of the housing below the carb what could that be from?
sorry it so long just want to go fishing.
thanks
CHris
thanks
CHris
