Pulling a tube
sid the squid
I've got a 2005 21' bayliner CC with a tow cleat(I guess that is what it is called) centered on the swim platform. Is it better to tow a tube using that cleat or would it be better to rig a harness using the aft cleats on either side. It is a one person tube, no one bigger than about 220 lbs. Thanks
boater56
Re: Pulling a tube
We have the same boat. We pull our two kids, one 7, the other 14, together all the time using the tow ring. I've never checked to see if there is a backing plate on it. Seems to work pretty good though.
Re: Pulling a tube
the aft cleats are designed for docking and mooring, not the extreme stress of towing. on some boats they aren't even thru bolted.
ruf1967
Re: Pulling a tube
That tow hook has a backing plate and is actually designed to pull a skier. I'm 200lbs and ski behind my boat with no problems. However, if you would really rather use a tow harness, hook it to the transom eyes not the stern cleats. Don't fret, just get wet!
NBE
Re: Pulling a tube
The transom eyes, if you have them, are probably your best bet. That is what they are made for, among other things. Use the tow harness with them.
Gary H NC
Re: Pulling a tube
My center tow cleat will pull a 3 person tube just fine...I have used the side transom eyes with a ski harness but prefer the center one..
