60 horse merc no electric start
wxpnwo
hey guys i could use a little help, heres the story was out on my boat and the motor stalled and it wouldn't start with the key but it will run when i pull start it I'm pretty sure its electrical where should i start? Ignition switch, power pack , or the starter it self? any help would be greatly appreciated.
cougar1985
Re: 60 horse merc no electric start
first find out if the starter etc is good. try jump starting at the selinoid.why im saying this is that if it starts that will discount the motor end of the deal. i had a older merc elct start and i found it was the battery cables from the control box were rotten on the inside. i kept cutting back till i found good cable then spliced on new stuff.
WillyBWright
Start at the battery. Take a pliers to those useless cause-more-problems-than-they're-worth wingnuts. Make sure the motor is in Neutral and the Dead-man tether is in place.
wxpnwo
ok guys i jumped the starter it worked i can get the boat to run when i pull start it just got a new battery today opened up my throttle to look at the wires and they looked alright im starting to wonder if my ignition switch went bad if it were the kill switch the engine wouldnt run at all
Have someone hold the key in the START position while you check voltage at the small terminal on the starter solenoid that comes from the ignitioin switch. If there is 12V there, the ignition switch is ok. If not, there is either a wiring problem or the switch is bad. Disconnect the large harness connector on the engine and check the terminals. Clean them and then reconnect. A bad connection at the plug prevents voltage from getting to the solenoid from the switch.
wxpnwo
ok i check the voltage with a multimeter and im not getting any power to the small terminal on the soleniod from the ingnition switch and the plugs pretty clean so what should i do next is it possibly to replace the ingnition switch? because its its in the throttle and when i took it out to look at it it looked sealed should i just cut the wires?
wxpnwo
i got it neutral lockout switch was bad
