what rpm is my 87 omc 5.7?
bandit86
Banned
I have prop issues, need to know what rpm it's supposed to run at, or can I just go by the red on the rpm gauge? at wot, should it ba right at red ine, or just a bit before it?
QC
Re: what rpm is my 87 omc 5.7?
I believe those were rated for 4200 - 4600 RPM wot. My recommendation is to ignore the red, however I am curious what RPM your tach says is redline. Just to be clear this is not your recommended cruise RPM, it is the recommended wide open throttle (wot) setting for a properly trimmed boat with average load. Being within this RPM band for those conditions will make for the best overall performance . . . best compromise between top speed and decent acceleration, as well as insuring safe operation at all points in between. If hole shot is your primary goal, you should shoot for the higher end of the range, if tops speed or efficiency are more important shoot for the lower end. Most will say the top end will give you the most satisfaction and flexibility, which I agree with.
P.S. You might get more help with this in the prop section . . .
bandit86
Banned
just checked, the redline begins at 45oo rpm
QC
Then the redline may in fact be correct and I would shoot for a prop that just hits it with an average load.
Purduebarry
There is a prop forum that will get you many more answers, repost there or the mods might do it for you.
