whats the diff between marine carb and auto carb?
waterdawg69
i was just wondering if there is much difence in an marine and auto carb . im wanting to get a new one . or if anyone knows a good place to get one at a cheap price the one i have now is a rochester 2bbl # 173 7028188 thanks for the help
Don S
Re: whats the diff between marine carb and auto carb?
Yes, there is a big difference, and an automotive carb should never be used in a boat.
The marine carbs are designed to have any excess gas in the fuel bowls and vents, vented into the engine and not outside as in automotive carbs. It's a safety issue to prevent fires and explosions. Same with many of the electrical components, alt, starter, distributor, etc. ALWAYS marine, not automotive.
Scaaty
Short version......
Slight gas leak from stuck float........
Marine Carb...runs a little rough
Auto Carb...fireball.... and make the front page AND the news. Plus your Insurance won't pay
ntheyer
I also went through this with a 2 barrel Rochester. The previous owner had an auto carb in it and the boat never ran right. The outside looks similar, but internally it is slightly different and never ran right over about 3/4 throttle. Don't do it even though it's much cheaper. You will have issues.
waterdawg69
how do you know if you have one already on it ? is there a way to tell
Don S
That carb is for a 1968 Kiekhaefer (aka Mercruiser) 6 cyl 250. It is a marine carb.
Google is a wonderful thing :)
http://www.thecarburetorshop.com/MkitDthruK.htm
Just out of curiosity, what engine do you have and what year?
searay3
Kiekhaefer 1968 6 250 Rochester 7028188 2GC 2821
Looks like you already have a marine carb.
waterdawg69
thanks for the help ts a 160hp mercrusier 4.1 250 the motor is a 67
waterdawg69
pic
Boomyal
Other differences not mentioned. Marine carbs have better sealing at the throttle shaft to prevent leakage out into the engine compartment. Also, at least some like Holley, have a more corrosion resistant finish on the outside.
Don S
Are you sure about that? I don't recall any differences there. It's on the vacuum side anyway and would suck air, not leak fuel.
Boomyal
Don, I'm sure that I read that on the Holley site.
Scaaty
Didn't make sense to me either, but my old Q-junk dribbled a drop or two when shut off out the shaft. Long ago, can't remember much about the ifs, and's or butts
Limited-Time
Sealed Accelerator pump shaft, spring loaded check balls, and special marine bowel venting to mention a few others......
JasonR
I was wondering if the marine holley has a different float setting, especially for the rear bowl. When mounted to my engine the carb has a drastic tilt towards the rear of the boat. My father-in-law (who is a hot rod freak) made the observation and said that a normal carb would have float problem tilted like that all the time.
Don S
Sure they have different settings than automotive.
The engines usually sit pretty leverl in an IO engine, maybe a little angle, but not enough to worry about. That is in the disign of the boat.
If you have a very steep angle, such as in some inboard installations, there are special intake manifolds and angled spacers that go under the carb to keep it fairly level.
JasonR
huh, my inboard doesn't have one but that doesn't mean it shouldn't
