2000 evinrude 15hp wont start
sammy.duvall
was running up creek yesterday full throttle pulled back on throttle to pass another boat motor died like the switch was turned off. wont restart. no spark. thinking ign switch but have no clue on how to test. where can i find a wiring diagram? thanks for the help.
Xcusme
Re: 2000 evinrude 15hp wont start
Welcome to iboats Sammy !
Can you post the model number of your motor?? Port side transom mount has the info on I.D. plate.
sammy.duvall
model # E15EL4SSE
ser # G04740068
what about he kill switch lanyard.
sammy.duvall
landyard still in switch.pulled it out and reinstalled it. even tried wiggling it while turning the key. no help.
sammy.duvall
tested for power at the coil while starting, no fire.
go to boatpartstore.com click on trouble shooting then the johnson/evinrude has some test that you an do. make sure is in neutral has safety switch, that acts just like kill switch.
sammy.duvall
ok will try that. there`s a few test there that i havent tried yet. thanks for the help. i`ll post after test test are done. thanks again!
