Idle screw + needle
urbanp
I'm trying to adjust my caruration on my inline 6 for a better holeshot, (its terrible right now) and i'm tring to figure out which adjustments on the carbs are Idle screws and airscrews. I'm using the post on inline 6's by Clams as my guide. Does anyone have a picture or a good description for me. (1976 1500)
Thank
Urban
Re: Idle screw + needle
If you mean idle "speed" screw -- it is linkage related and there is only one. Each carb has a "mixture" screw with a spring under it.
urbanp
Can anyone id the screws in the image for me? I'm guessing the yellow arrow is pointing at the mixure screw, but i'm not sure
thanks
[attachment=img=P1020140 carb]
urbanp
i'm having trouble attaching a pic off my computer, if anyone knows these carbs well, i can email the pic.
urbanp
[attachment=img=null][attachment=img=P1020140 carb]
urbanp
here is the pic
urbanp
or not
Plainsman
Try uploading your pic to www.photobucket.com amd paste the link in your post. You also may want to get a manual before you adjust anything.
Deep_Blue
ahh yes, same carbs that i have. my manual doesnt describe them very well. so yellow is air mixture. but what is red or green????
Deep Blue, Red, green and blue arrows are brass covers or plugs over the different fuel and air passages within the carb body. These need to be snug so there are no air or fuel leaks.d:)
Clams Canino
Actually the screw meters FUEL not air. Screwing it in all the way stops fuel. Adjust them as per my instructions. Past that, if all else is correct, a poor hole shot usually means it's overpropped and will soon be melting a piston 1st time the Cods look at it sideways.
-W
