'94 Mercruiser 350 MAG - Stalling, tachometer pegs
GrantMan
First time poster here, please be kind. Buddy of mine suggested this as a good resource to help diagnose my problem.
I have a 1994 19-foot Bluewater Mirage with Mercruiser 350 MAG and alpha-1 outdrive. I purchased it new and it has had the same intermittent problem since the day I put it in the water.
At random times the engine will momentarily stall, and when this happens the tachometer will peg-out at 6,000 RPM. The engine is not running at 6,000 RPM, the tach just jumps to the right peg as the engine is stalling. There does not appear to be any other common symptoms. Sometimes we’ll take the boat out without any problems. Sometimes this will occur a dozen times during a day of family waterskiing.
I’ve had the boat into the dealership at least a dozen times. Each time they would replace a part and call it “fixed”. We’d take it out a couple of times until the engine would stall again then take it back to the dealership.
The last time it was in the dealership (1996) they were convenienced they had found and resolved the problem. Soon afterward our first daughter was born and the boat has been in the garage ever since, I took it out and ran it once a year to burn out the bad gas, then winterize it. Basically just keeping it running until the kids were old enough to enjoy it with us. During this “down time” the dealership has gone out of business and the problem has re-occurred.
I’m not sure what to do. Between 1994 and 1996 the dealership spent untold hours trying to figure this out under the warranty. They never did get it fixed. Now the dealership is closed and I can’t afford to pay for hundreds of shop hours chasing this problem.
Has anyone heard of this problem before? What possible problem might cause both the engine to stall and the tach to immediately peg-out-to-max?
Reel Poor
Re: '94 Mercruiser 350 MAG - Stalling, tachometer pegs
Has the tach been replaced. If not disconnect it and run the boat long enough to see if the problem reoccures.
GrantMan
Yes, the tach was the first thing the dealership replaced back in '94.
JoJoBetsy
This sounds electrical which means you have a rabbit hole to go down. I just had one myself and with a little patience and of course cash for parts, you can get this fixed and not have to worry about it anymore. Have you taken the boat out this season to see if the problem will replicate itself? Make sure you have covered all the basics for a good running motor, e.g. new tune-up components as well as clean fuel.
Do your best to describe exactly what occurs, what you have done to diagnose the problem thus far, and what you have repaired/replaced and there will be help (or suggestions at least) along the way. Also, with the motor's serial number handy, purchase a Mercruiser service manual for the motor. Now that you are sans dealership, you will need to have the right manual(s) handy.
Electrical rabbit holes are the best!!
Don S
The tach may not be the problem, but it could be in the tach wiring. Disconnect the gray tach lead from the coil and see if that cures the problem.
ccfarm5
GrantMan,
Please be so kind as to post any resolution you may find, as I have been experiencing the very same problem with my 97 5.7L EFI. I spent $1000 with the dealer last year trying to rectify the issue, and it still stalls/pegs the tach. I am frustrated to the point of throwing parts at it, starting with the coil, and ignition module, followed by burning tires and a call to my insurance man. Best of luck.
Chad
Don S
Chad, instead of hoping for a reply, why don't you start a new thread with your problem. Lots of differences between and EFI and a Carbed engine.
Also be sure to post your engines SN boat and engine years are seldom the same.
