Good Preventive Maintenance Suggestions
mikey30345
Would everyone agree, on a 10 year old Force motor, (120 hp - that has been correctly maintained, but by someone else) that the BEST preventive maintenance, to be done every 2 to 3 years is:
1) A water pump impeller change;
and ......
2) Changing the lower end lube/grease.
Any other smart ideas ???
Motor runs superbly and has always been used in fresh water.
All suggestions/thoughts are greatly appreciated, in advance.
Mikey Lulejian
Lake Oconee, GA
roscoe
Re: Good Preventive Maintenance Suggestions
Welcome Mikey.
While a water pump can be done every few years, the lower unit lube should be done every year, in fall, when you winterize the motor.
Clean her out with a Seafoam Deep Creep decarb treatment annually.
Rebuild the fuel pump every few years.
imported_LakeRunner
and a light coat of fogging oil on the engine to help keep corrosion down...
