The B440 lay-up resin is the product on the left that we ordered 2 gallons of from US composites. Our estimates were running at right at 2 gallons of resin plus or minus a little for the project. The US composites resin is layup resin and it not waxed, so if we use it for a final coat we need to add wax to the resin when we mix in the MKEP, and we had done that for small batches with no problems..
We did the entire floor install, made putties, did the taping as well as the transom lamination and install with this resin. We also put down the 1st layer of 7 oz glass clothe over the entire floor with this resin. B440 is very easy to work with. It has a nice wet out and consistent SLOW setting. We installed the 1st layer of cloth on the floor as 2 - 50 inch wide panels that ran across the floor and had a seam running across the boat right behind the drivers seat.
We had 0 ZERO problems wetting out and laying the 1st layer of glass. No bubbles, no wrinkles. The wood grain showed through the cloth and resin beautifully. We still had time after the entire layer was done to do some minor tweaking of the clothe before it totally setup.
So, the plan was that we were to finish off the floor with a 2nd layer of the same cloth running from the back of the boat up to the front of the boat. Because this was to be our final layer we needed a finishing resin, a waxed resin, or we needed to add wax to the USC resin.
Well we didnt have enough of the USC resin left to do the entire job and we had some things to finish on the transom, so lets hold on to the remaining resin and do get ourselves some finishing resin.
Wholla, product 2 on the right in the photo is purchased (we are purposely NOT naming the product because we are so PISSED about the quality of the product, and we dont want to get in a lawsuit)
This resin is a waxed finishing resin and all indications are that you catalyze and use it exactly like the previous USC resin. WRONG !!!.. Absolutely, totally DEAD WRONG.
We mixed the 1st pint batch of this resin at 1% MKEP like all of the other batches of USC resin that we had mixed. First off the wet out was problematic and we needed allot more time to work the resin into the cloth, this resin was NOTICABLY thicker than the USC resin and it didnt wet out as easily. 2nd about ½ of our 1st batch of resin setup in the pot before we could use it, like in under 10 minutes.. Keep in mind that we had USC resin catalyzed at the exact same rate that took 30 minutes to jell. (We are operating in early June, at maybe 65 to 70 degree temperatures)
So we start mixing batches at ¾% MKEP and finally wound up thinning the resin 10% with styrene and mixing at ½% MKEP and it STILL setup in the pot.
We went from one layer of cloth that looked nearly perfect to a finish layer of cloth that looked like a 10 year old had laid it. Obviously we are not the least bit happy about this situation. We were working towards that being our final layer of cloth on the floor and not having to go back and glass it again.
Now we get to grind down the ENTIRE floor, get more cloth and more, USC resin this time, and cover the entire floor with a 3rd layer of glass.
So, my recommendations:
1. Buy your resins from a resin supplier, like USC, not from the auto parts store.
2. Always do jell time tests on resins before you use them.
3. Always do jell time tests on resins before you use them.
4. Always do jell time tests on resins before you use them.
