Overheat at idle 305chev
POINTER94
Hey guys we have a 1990 mercruiser 305 with an alpha 1. At idle it overheats. Seems simple enough. We have replaced the thermostat first, then the impeller, then the water pump on the engine and finally changed the hoses from the outdrive to the engine. Took it out tonight and it is still overheating at idle.
WTF. We are dying on this one. Any ideas, if not prayers would be gladly accepted.
Don S
Re: Overheat at idle 305chev
Manifolds or risers could be starting to plug up.
The impeller housing could also be damaged and let it work ok at higher speeds.
POINTER94
Thanks for the reply don. We replaced the manifolds about two years ago and it is used in fresh water exclusively, and probably has about 75 hrs. on it since replaced but I dont think the risers were ever looked at. That wil be my next look.
We had the outdrive completely replaced last year with brand new, not rebuilt. It better not have a defect in the impeller housing. But stranger things have happened.
Thanks for the solid info.
Reel Poor
You said you replaced the impellor. Was the old bad and comming apart? If so,,,,Did you find ALL the pieces?
POINTER94
Reel Poor,
Actually there was nothing wrong with it. We change the impeller almost every year as part of preventive maintainance. It actually looked brand new.
Blk-n-Blu
This might be of help:
TEMPERATURE PROBLEMS
WARNING: IF A TEMPERATURE PROBLEM IS SUSPECTED, BE CAREFUL. THE COOLING SYSTEM CONTAINS HOT LIQUID UNDER PRESSURE AND A CARELESS OR THOUGHTLESS ACTION COULD RESULT IN SEVERE INJURY.
TEMPERATURE GAUGE PROBLEMS
Before spending any time trying to diagnose a temperature problem, make sure that you really have a problem. Temperature gauges, especially the electric type, which are the most common in boats, are often very inaccurate and have temperature scales that are difficult to interpret. Therefore, before worrying about a suspected temperature problem, check your temperature gauge against a thermometer of known accuracy.
NORMAL TEMPERATURES
Most marine FWC thermostats open at 160 degrees F and will be fully open at approximately 180 degrees F. A new clean system under moderate load should operate at the lower end of this range and a dirty system under full load might operate in the upper range. Anything outside of this is abnormal and should be investigated.
OVERCOOLING
The most common problem is a temperature above the thermostat range--overheating. The opposite may also happen and will create long term problems. Any good FWC system should have excess cooling capacity. This compensates for the inevitable decrease in cooling capacity that results from the normal gradual buildup of dirt on the heat transfer surfaces. In order to make sure that such a system, when new and clean, does not overcool, a thermostat is used to control the flow of coolant to the heat exchanger. An overcooling problem therefore, has a single simple explanation. The thermostat is not functioning properly. Check to make sure that it is of the right type and properly installed. Do not assume that just because it fits it will function right. There is a lot more to thermostat design than most people realize. Do not experiment with unapproved thermostats. If the right type and correctly installed make sure thermostat functions properly by immersing it in hot water of known temperature. Easiest way is to use a pot of water on a stove with an accurate thermometer. Hold thermostat by the flange with a pair of pliers. Do not let either thermostat or thermometer rest against bottom of pan.
Thermostat should open at temperature marked on it and be fully open approximately 20 degrees F higher. It should close again when immersed in colder water. Malfunctioning thermostats cannot be repaired, they must be replaced: Make sure you get the right type.
OVERHEATING
Overheating problems can be categorized into three basic problems that either alone or in combination with one another, will create overheating. They are: lack of raw water flow, lack of fresh water flow, and heat exchanger defects.
LACK OF RAW WATER FLOW
Lack of raw water flow will show up as an excessive increase of the raw water temperature as the raw water passes through the cooling system. Normal temp increase varies between different engine models but is usually in the range of 40 - 60 degrees F. In other words, if incoming raw water temperature is 70 degrees F, the outgoing water passing through the exhaust elbows will be in the range of 110 - 130 degrees F. This will create surface temperatures on the elbow that will be warm but not excessively hot. So the easiest way to identify a raw water problem is to check whether or not the engine overheating is combined with excessive temperatures on the outlet side of the raw water system.
If the raw water side is to blame there could be three basic reasons.
RESTRICTIONS ON INLET SIDE OF RAW WATER PUMP
They could either be design problems such as undersized plumbing or maintenance problems such as debris buildup in seacocks, strainers or other components located on the suction side of the raw water system. Check and clean
PUMP PROBLEMS
The most common pump in use today is the rubber impeller pump. The impeller in this pump must never be run dry or it will be ruined. Eventually this impeller will also lose some of its flexibility due to old age and lose capacity.
In order to be on the safe side, we recommend that you replace the impeller annually especially if it is located in the sterndrive and difficult to service during the season. Keep the old impeller as a spare. If the impeller is damaged with blades missing, make sure that you find the missing blades. They could be stuck downstream from the pump interfering with proper flow. If raw water pump is belt driven, make sure that belt has correct tension.
RESTRICTIONS ON OUTLET SIDE OF RAW WATER PUMP
These restrictions are often in the form of raw water debris accumulating on the inlet side of oil coolers and heat exchangers. Always check the units closest to the pump first and work yourself downstream.
EXHAUST ELBOW CLOG
Over a few years, a problem with rust buildup in the exhaust elbows may develop. Many exhaust elbows have several small holes in the area where the raw water enters the exhaust pipe. These orifices are designed to ensure proper water distribution at this point. Unfortunately, because of their small diameter they tend to get clogged with the rust particles that a raw water-cooled elbow gives off. Eventually, an exhaust elbow may get completely plugged up preventing raw water from entering the exhaust pipe and thereby creating a fire hazard. In an in line engine with a single exhaust elbow, this complete blockage will automatically cause engine overheating before the exhaust overheats. This will signal a problem before a fire hazard develops. In a V-type engine however, the situation is more dangerous since one elbow could become plugged and the other one not. In this case, sufficient raw water may be able to exit through the open elbow to keep enough raw water flowing through the engine heat exchanger. The engine may not overheat but the plugged elbow and matching exhaust manifold and exhaust pipe could burn and be destroyed. We recommend that you periodically during the season feel the exhaust elbows to make sure that they stay at a normal and even temperature. Clean or replace these elbows before they cause further damage. Periodic flushing of the engine with fresh water will help minimize these problems.
LACK OF FRESH WATER FLOW
Lack of fresh water flow will show up as an increase in the temperature difference between in and outlet of heat exchanger. Most modern engines have a flow rate at a level where the temperature difference between in and out on a block only system, will be in the range of 10-20 degrees F. If manifolds are included in fresh water system, add another 10-20 degrees. Most people find 140 degrees F to be the approximate max temperature that they can leave their hand on without discomfort. Since fresh water temperatures normally are above 160 degrees F, it is not practical to check this difference without special equipment. If the engine is cool enough to be touched it is probably running too cold.
If lack of fresh water flow is the problem, these are the basic causes of it.
RESTRICTIONS ON SUCTION SIDE OF JACKET WATER PUMP
Besides design problems such as an undersized heat exchanger outlet connection and/or hose, the only thing that can go wrong would be a hose being sucked closed. That is why hoses on the suction side, unless they are very short, should either be wire-reinforced or have a loose spring inside to prevent collapsing.
PUMP PROBLEMS
Some older designs may have a rubber impeller pump or even gear pumps. If so, the rules relating to raw water pumps apply. Since rubber swells at increasing temperatures, it may be a good idea to give the pump impeller more space by using a thicker gasket under the pump cover. Also, it is a good idea to use a full 50/50 antifreeze solution since the antifreeze will help lubricate the pump. The vast majority of modern marine engines use the standard automotive centrifugal jacket water pump. If these pumps have been operated in a raw water system they may have corrosion damage and may need to be repaired or replaced. Otherwise, this pump is very trouble free. The only service necessary should be to make sure that it operates at proper speed, by checking that the drive belt is not slipping. In the long run, it may develop a leak or bad bearing, just like in a car, but will continue pumping and is seldom causing overheat problems. Be aware though that if the engine is opposite rotation from the automotive standard, the pump may have a somewhat lower flow rate, which may result in slightly higher operating temperatures.
RESTRICTIONS ON PRESSURE SIDE
In this category will belong internal blockage in the engine, malfunctioning thermostats, and restrictions in the inlet side of the heat exchanger.
ENGINE INTERNAL BLOCKAGE
It is very unusual that a fresh water-cooled engine would have this problem. If an engine that has been operated on raw water is converted to FWC, it is possible that old rust and scale deposits will create restrictions. That is why it is important to try to remove as much of this rust and scale as possible, as part of the installation process. Some of the debris may not come loose until normal engine operating conditions with higher jacket water flow, heat, and vibration. It is unusual that this debris will create blockage within the engine. More likely, it will be flushed along and get struck in the heat exchanger.
THERMOSTAT PROBLEMS
The thermostat has a very important function in any cooling system. If stuck in an open position it will cause overcooling and if stuck closed, overheating. Its function is more complicated than most people realize. Even a fully open thermostat creates a restriction at the outlet of the engine. This restriction is designed into the system in order to build up pressure in the engine block to help suppress localized internal boiling. Removing a thermostat that is not opening may work as a temporary solution to an overheating problem. If so it should strictly be used in an emergency and the engine should only be operated under minimal load. As to how a thermostat should be tested see previous discussion about overcooling problems.
RESTRICTION IN HEAT EXCHANGER
Any debris that may work itself loose in the engine block may be flushed along and get stuck at the inlet of the heat exchanger a form a restriction. If this happens the heat exchanger should be back-flushed, that is flushed with water going in the opposite direction from normal. Depending on heat exchanger design and location this may or may not be possible to do with the heat exchanger installed. The best way is to do it with the heat exchanger removed so that it can be turned with the inlet down and let both water flow and the force of gravity help remove debris.
HEAT EXCHANGER PROBLEMS
Since heat exchangers contain no moving parts there is very little that can go wrong with them except that they can get plugged with debris and that they will become dirty. They can also develop leaks internal as well as external. These problems will be covered in the next category of troubleshooting. There is also the possibility that a heat exchanger is insufficient in capacity and/or incorrectly manufactured. Those problems, however, will show up immediately upon start-up and the manufacturer should be contacted. In this discussion we are concerned with the problems that could develop during normal usage.
DEBRIS BLOCKAGE
The most common problem is where enough debris accumulates in the inlet chamber of the heat exchanger to prevent the raw water from passing through the tubes and pick up the heat. Since all good heat exchangers should have an existing de-mountable end cover at the inlet and it should be a simple operation to remove this debris. If the problem persists due to local water conditions install a good capacity raw water strainer in the raw water inlet hose. Even better is a good hull mounted strainer that will prevent debris from entering the system in the first place. Obviously there is a different solution depending on whether the raw water intake is through a seacock or a sterndrive.
DIRT BUILD-UP
The more long-term problem with heat exchangers is the gradual slow build-up of dirt on both the inside and outside of the small tubes that form the heat transfer area. This will gradually build up as a layer of insulation and is compensated for in every good heat exchanger design by so called "fouling factor". This simply means the heat exchanger has excess capacity when new and clean so it still performs acceptably when old and dirty. However, this "fouling factor" can only go so far and eventually a thorough cleaning of the heat exchanger may be necessary. The most drastic solution is to remove the heat exchanger and bring it to a radiator shop for a complete cleaning.
Make sure that the radiator shop has experience with marine heat exchangers. Proper cleaning should be a two step operation. First clean the unit with a strong alkaline solution to remove organic dirt such as oil. Second, in order to remove scale, the unit should be cleaned in an acid solution.
If a less thorough cleaning is desirable the heat exchanger can be left in the system. The jacket waterside can be cleaned in the same way as an automobile cooling system using any of the better radiator cleaning solutions on the market. Using a small diameter long handle brush similar to what is used for cleaning a rifle barrel can clean the small tubes on the raw waterside. It is possible to acid clean the raw waterside of the heat exchanger without removing it from the boat, but it is messy and dangerous. The ports of the heat exchanger will have to be plugged and the unit filled with an inhibited muriatic acid. Since an operation like that necessitates special safety equipment and creates a disposal problem we do not recommend that you try it unless you really know what you are doing.
LEAKAGE PROBLEMS
External & Internal Leaks
External leaks are the ones where the liquid leaks to the outside of the cooling system and can be seen or felt. Internal leaks are impossible to see or feel directly since they allow liquid to leak into internal area of the cooling system or the engine itself. Since they are more difficult to find and therefore may go on longer, they are often the most serious ones.
Raw Water Leaks
External leaks
On the raw waterside seldom in themselves create major problems until they reach a high level. They should be fixed since a small leak easily could develop into a major one. Also raw water can do major damage if allowed to come in contact with other components especially electric ones. Besides the direct damage that a raw water leakage can do, it may also be a warning signal for other problems. Leaks may start due to pressure build-up in the system resulting from raw water blockage in either heat exchangers or exhaust system.
Internal leaks
The result of an internal leak will depend on the pressure existing on either side of the leak. On a FWC equipped engine, raw water can still enter internally into the engine or transmission through raw water-cooled oil coolers. Raw water can also get into the engine jacket through the main heat exchanger, as well as enter the engine cylinders through leaky raw water-cooled exhaust manifolds and exhaust elbows. Any of the above fluids may also go the other way and enter the raw water system. Which way the leak will go will depend on which fluid is under the most pressure and usually will depend on whether or not the engine is running. The leak might go one way when the engine is not running and the other way when it starts up. Either way these leaks are very serious and must be caught early or serious engine damage may result. Check engine and transmission fluid levels frequently and be alert to any abnormal changes in levels as well as condition of fluid.
Fresh Water Leaks
External leaks
On fresh waterside may eventually create enough loss of coolant to create an overheating situation. Once the safety margin in the expansion tank is used up, air will enter the closed system. Since a mixture of air and coolant is insufficient as a heat carrier overheating will result. Some leaks may be difficult to find unless system is under pressure. This pressure is created by normal engine temperature. Since trouble shooting for safety reasons should be done on a cold engine, the system may have to artificially pressurized to show a leak. A solution to this problem is a pressurizing pump for trouble shooting automobile cooling systems available from most auto supply stores. This type of pump usually includes a pressure gauge that will confirm the presence of a leak.
Internal leaks
On the fresh waterside can be in the heat exchanger internally where the fresh water will leak out into the raw waterside and escape. To check for this type of leakage, remove end covers from heat exchanger and drain raw water. Most antifreeze solutions have a color to them and are easy to see if they leak out into the raw water part of the heat exchanger. If operating on plain water, it may be desirable to dye water with food coloring to be able to see. Pressurizing the fresh waterside will help locate the leak. Another more serious form of internal leak that would be one within the engine where the fresh water, in most cases actually an ethylene glycol solution, leaks into the cylinders through a leaky head gasket. This type of leak will usually show up when combustion gases are pushed into the jacket water when the engine is running and under load. It may not show up at any speed unless the engine is under load. It will show up as a steady stream of bubbles being pushed through the clear tubing leading from the heat exchanger to the expansion tank. Do not confuse with normal start up deaeration. A device called "Bloc Check" is available from the auto supply stores which will analyze the gases being pushed out from the cooling system and show whether they are air or combustion gases. A leaky head gasket problem is very serious and should be attended to immediately by a professional mechanic. It may result in Ethylene Glycol contaminating the oil. This is why we recommend running an engine initially on plain water to confirm too that no leaks exist. At worst, the leaking coolant could accumulate in a cylinder and upon start-up bend a connecting rod due to hydraulic lock.
Fixing Leaks
Permanent Repairs
The best way is obviously to create a permanent solution by bringing the leaking components into the proper condition. If major components such as heat exchanger leaks make sure they are repaired or replaced by competent professionals, preferably by referring them to manufacturers. Use only the material suitable for marine use. Make sure that you get to the root of the problem so that you don't put a "patch on a patch". If a problem appears persistent or suspicious make sure that you carry enough tools and spare parts aboard so that you have a chance to fix it again if the problem would reappear while underway.
Temporary Field Fixes
They should strictly be used to bring you back from a trip to proper repair facilities. Auto supply stores normally have hose repair kits that could come in handy. Also available are cooling system sealers. These products can be tried as temporary solutions to leaks on the fresh waterside. Hardening putty of an epoxy type if also available and may prove useful. Always carry extra hose and hose clamps aboard for emergency repair.
George Van Parys, http://www.boatfix.com
POINTER94
thanks blk n blu, if this don't get us there nothin will.d:)
Appreciate the post big time.
Purduebarry
BNB if you had to read and sign this before buying a boat I'd venture to say nobody ever would. And this is just for the cooling system! Kinda puts things in perspective...but it's just a boat and a motor, what's the big deal, put in gas and drive it! Nice thread.
One quick check on the fresh water supply is to disconnect the supply hose from the out drive to the recirculating pump. Briefly start it, and look for a 4-5 inch column of water when held at the top of the block level @ idle speed. If the column is weak, check the hose/piping in the gimbal area for leaks. If the column is good, then pull the risers.
POINTER94
I have to apologize. We started from scratch again and found that the sensor for the temp gauge was faulty. There was never a problem with the cooling system. We have confirmed this with a temp gun. We have ordered a new sensor and will install later this week. It wasn't a complete waste, the bellows needed to be replaced, and a new water pump isn't terrible expensive and a 17yr. old boat can only benefit from a new one. But it put a damper on boating for the owner for a couple of precious weeks here in the height of the season.
We determined this with a heat reading gun and tapping on the sensor. The temp recovered extremely fast when the engine was revved, and tapping on the sensor caused the gauge to go goofy. I assume the dissimiliar metals have corroded or been compromised over the years. We will confirm this when we install the new sensor and I will report back.
Cost to date for this issue about 700 bucks. Real cost to fix, 27 bucks and 15 minutes work. I should have asked sooner. All posts were outstanding but special thanks to blk n blu, that should be in the FAQ section. It was the first paragraph that sparked the discovery of the bad sensor. Thanks all.
FWIW, this is my brothers boat. But he is shy about asking for help on line.
Blk-n-Blu
Good to hear you have narrowed it down. When you are sure you have the problem fixed, be sure to update us. Look in the" Interact drop down window" in your original post and add update to the subject line.8)
