Re: 18 hp tohatsu runnig bad at speeds
While Elvin will respond "Any Nissan or Tohatsu Dealer", do not be afraid to give him a call. d
But, before shotgunning the coil, it is probably rather expensive and non-returnable, swap plugs and retest. If it moves with plug, its not the coil. Next, check the primary and secondary coil windings with an ohm meter. The manual has the acceptable ranges for each. But, assuming you have two coils in one module, you should be able to compare the primary to primary, and secondary to secondary, without the manual. The differances might be enough for you to pull the trigger on that shotgun.
Did I mention geting a manual? d
