2 plywood sheet boat plans
awnee
my uncle told me about a guy who made a boat out of two sheets of ply wood and put a 25 hp motor on it im verry interested in building one like it
Pony
Re: 2 plywood sheet boat plans
There are a ton of links/plans out there. If you go to boatbuildingonline.com and click on "links" it will bring up a dozen links. Plus a lot of people there have built boats from plywood already and have lots of great tips One actual makes boat plans.
Kevin70
I've also been working on this 14' flatbottom. It took 5 sheets so far. I still have to build the benches and a casting deck inside. Then fiberglass inside and out. It's suppose to hold up to a 35 HP motor.
kevin going to be a nice boat.
awnee
Thank you for helping me find that kevin it looks like one i really want to build thank you for your help!
awnee
Kevin, on the boat in your first entry, do you think i could soup up the transom a bit to fit something a little bigger than a 2 horse motor on it if not thank you for your help anyway.
Kevin70
Oh yeah, You can make it one and 1/2" thick and add a few extra layers of glass and it should hold up to a 35 HP. Just make sure that the transom glass wraps around the boat at least 2 feet. And make sure you encapsulate the ENTIRE boat with glass. Some people say that epoxy is better, but a glass boat is alot cheaper and, if done right, will give you 20 years of maintenance-free boating....(at least the boat itself, anyway)
Kevin70
Here is a [colour=red]picture[/colour] of that transom I was talking about. It's a solid 1 1/2" thick. I left the small gap between the two pieces so that it could be filled with fiberglass resin putty. I've seen folks hang a 90 HP off of far less.
sanssouci
This one was built with three pieces of plywood. The bottom has fibre glass with epoxy.
Kevin70
Oh, see there......Now you got me wanting to build something else.....Sweet.
awnee
Sanssouci, where did you get the plans to make that boat, it looks like a lot of fun.
sanssouci
That is a Glen-L design TNT. If I were to build another I would shorten the transom and modified the hull with a vee.
bassboy1
Kevin. How much will your boat weigh upon completion?
Kevin70
Without the motor, about 300 lbs.
