funtwohunt
- Joined
- Jul 19, 2003
- 2
Hasn't been run in 2 years. Checked carbs and they looked good. They were drained before stored. Put in new gas, pumped up the ball. Checked the oil injection tank, half full, pumped until ball solid. Motor fired right up. Sounded great in a barrel of water. Gears shifted O.K. etc. Took it to the lake and unloaded it. Started it right up, backed off trailer, put it in gear and throttled up a bit seemed to be O.K. Went to about half open, 3000 rpm running good. Opened it up some more in a minute or so after it warmed up a bit. Went full throttle, motor started to rap up as usual to about 5500 rpm, then it bogged out and will run maybe 3000 rpm under load. Seems to be hitting on all cylinders. Neutral it will rap 5 - 6000 rpm. Idles great hitting on all three cylinders. We kept it slowed down and pretty much cruised a bit thinking it might clear out. It didn't, then the oil injector alarm came on, we shut it down, pumped the oil ball and restarted and alarm stayed off.
Removed & Cleaned the carbs thinking they might be plugged from storage. Didn't help any.
Any ideas?
Thanks, Funtwohunt
Any ideas?
Thanks, Funtwohunt
