Re: Johnson 33HP Super Seahorse
Yeah, that's for gapping spark plugs. Which is not what we're doing here. When you do this test, the spark plugs are sitting on the work bench. (or more likely in the lower pan!
The thing I'm talking about looks like this:
Of course, it can be replaced by the alternative method of banging two nails into a board. The idea here is to force the spark to jump a gap that's wider then normal, which simulates firing under compression.
