caper_45ca
Thread starter- Joined
- Jul 5, 2005
- 147
I had the opportunity to take my boat for a good run this weekend and the main fuse from the soleniod is blowing again...I had the boat to the dealer here and he replaced the key switch which he said is what was causing the problem...well he was wrong:'(....like i said in a previous post it seems after about 20-30 mins of running this fuse blows and i loose my tach and t&t...but engine runs just fine....I've searched the wiring from stem to stern and cannot find anything that looks like it may cause this problem....what really gets me is that the fuse will not blow right away, it seems to blow over time.....and i cannot find anything that i am doing each time to even give me a clue as to the culprit.....can anyone suggest some way to try and diagnose this problem....forgot to add....1995 johnson 90 hp....mod j90tleor....only has 4 hrs on it since rebuild
