CDN BEAVER
Thread starter- Joined
- Jun 29, 2006
- 22
Hello,
Ive got a Seloc manual for my 1985 18XD motor. It basically tells you how to check the timing, but Ive still got afew questions.
1. First check is supposed to be down at full throttle. How is this done safely? I use a large garbage can to test run the motor, but as soon as any forward throttle is given most of the water gets tossed out of the can, causing me to shut down the motor before the water pump cavitates.
2. How do I go about tempoarily installing a tach? Will any tach work?
I probably have afew more questions that I cant remember right now, but thanks for the help.
Cheers.
Cheers.
