jedimaster
Thread starter- Joined
- Jun 8, 2006
- 336
Ok so I have decided to plunge in.
Head first without checking the depth first. I am sure I will hit a rock but oh well. Thats what insurance is for. This will be a diary with questions asked of ou fine folks. I didn't get very far.
I took the lower unit off and rechecked the water impellor everything seems fine. This leads me to believe it is the water hose that is the culprate.
Sooo. here we go.
Removed the rams, left the hydraullic line intact and just removed the two bolts on the back side and loosened off the transom side ones as far as possible, then removed the back sides and let the hang on the front through bolt.
Removed the six bolts that hold the drive to the bellhousing.
Tried a bit of tugging and a bit of prying careful not to wreck anything and then I just tilted up the drive about 3 inches and dropped it.
The unit popped free hopefully didn't break anything. As I pulled the drive off alot of water came out.
Set aside the drive.
As I look into the Ujoint bellows I see water, but no oil.
So I guess the oil seal is ok but the Bellows is shot. This would be my slow leak into the boat.
I also checked the gimbal bearing and it is definatly gone. very loose and noisy.
Ok, now I removed the trim sendors, and got stuck as I don't have the fancy hing pin removal tool.
Oh well thats it for tonite will have to hit the marina tomorow.
Maybe if I call around one will lend me the tools if I buy the transom kit from them.
Thats about all for now, I will keep this updated as I go.
Sooo. here we go.
