1996 30hp mercury
cbster
I have a motor that runs great but it idles a little rough it just started doing it so I changed the spark plugs and that didn't fix it. I am going to buy some sea foam tomorrow and try that. is there anything else I need to check? this is my first boat so I really don't know much about the motors. Thanks Greg
05GlastronSX
Re: 1996 30hp mercury
try sea foam and see how that works for you. my bet is that after you use it, your engine will run at idle or WOT just as if it were new. if sea foam doesnt work, clean the carbs.
