Re: RPM's
The numbers you list figure out to a negative 5% slip...impossible. Tach or speedo (both) are off.
you're about 1200-1300 low "IF" your tach is correct..
And "if" your tach is correct, your speed is way off...about 52mph at best. are you using GPS? If you are, and 60mph is what it says then your tach is way off and you're turning about 5300, which is still too low, almost lugging.
This engine likes 5800 real well. The manufactures specs from 1985 say 4500-5500,(could be 4750-5750 on the GT/XP) but with the crappy fuel we have today, we find it best to get the crossflows on up to 5800 for best results. Your GT/XP 150 uses the same block as the 200 with different port-timing than a std 150. It also has a tad more compression from different heads than std 150's have.
I have the same basic engine as you with a few added features, and when I'm testing props, I found that when I get down close to 5250RPM, My cylinderhead temps rise quickly at that point. I have Boyesen reeds and these allow more RPM, but for the most part, only above about 6400RPM. I've ran this engine over 6000 continuously for many hours now and it's the most trouble-free engine I've had. For everyday use, 5800 is best. That 24 Raker is a hard pulling prop and it takes alot of engine heigth to get all that 24 has to offer.
