Re: can I add a telltale
There are many variables, as to your press. readings. ie: length of tubing, how its routed, guage etc.
The main thing is to try to run the tubing to guage , with the least amount of bends , and as level as possible .
Though , it usually will be slightly , up hill.
As long as you get a reading that increases with rpm's your , OK.
You'll want to monitor the readings at various rpm's up to WOT.
Then just keep an eye on it for any pressure changes.
ie: if you run alot at say 4500 rpm's , note the pressure at said rpms.
Then you'll notice any change.
Then you can determine the cause.
For reference my 115 hp, at 5600 rpm's has 18lbs. press.
At idle 900 - 1000 rpm's , 7-8 lbs.
KYHunter
