first time out this yr fired up no problem took off on the river full throttle for 30 minutes. Shut it down for 30 minutes. Fired back up no problem drove back to the docks full throttle 30 minutes once at the dock throttled down for approach engine started to stall and finally did.
went to start up again engine turned over very slow couple cranks at a time then a few quicker ones and finally fired up again. Normally the second I turn the key it's running. (this was odd). Anyway this past weekend took it out to the lake launched and went to fire it up same thing wouldn't go Starter very hot as well as the positive terminal on the battery. Yet my engine tilt, lights and pump all work fine. Had to put a booster on it to get it going. Another odd thing once we got it going and headed out on the lake. Got to where we were going shut it off for about 3 hours. When the time came to head back fired it up. (turned over very fast like normal)
Half way back stop for a quick minute at at buddies dock. Turned it off for 5 minutes would start again
turns over very slow. Put the booster back on which now had a low charge on it. Wouldn't work. Kept try without the booster. Out of the blue starts cranking normal and starts.
Question does it sound like a short in the solonoid bad stater cables?????? At a loss.
Thanks in advance for any ideas
