MASTER Brian
Thread starter- Joined
- Mar 26, 2006
- 738
I am rebuiliding my power head and while it's off, I decided to replace the water-pump. When I went to drain the fluid I found shavings on the drain plugs, so I guess I will be going through the entire lower unit.
I have the L.U. off and on a bench and the prop isn't off yet. Do I need a special tool to take it off or should it come off? Any other special tools needed? I noticed there seems to be some sort of pullers used in the manual. Are those necessary or can I get by with automotive type pullers?
I have an OEM manual and this is a 1986 Evinrude XP 150 engine. Are there any parts I should definately replace while I'm tearing into it, or what about any other pointers/things I should look out for.
Thanks.
Thanks.
