Where is my alternator?
ToyBoat5X
This may be the noobiest question in the world but does my 1979 Mercury 90hp I6cyl. have an alternator? If not how do the batteries charge?
Thanks
Andy
Deep_Blue
Re: Where is my alternator?
It uses a rectifier :love:
question from a noob,
answer from a noob.
what’s the difference?
ToyBoat5X
HAHA!
well, Im planning to put a cd player and speakers in the boat, will that be okay? the boat has two batteries BTW. The rectifier looks small and doesnt look like it does much.
Thanks
Andy
Bob_VT
It charges off the stator and you should have no problem with the cd player.... remember that the boat plugs are not resistor type so the radio will be picking up every firing pulse.
Deep_Blue
Battery’s act somewhat as filters; however if you are picking up pulses just put a capacitor in line with all your stereo equipment (should solve most everything)
Unregulated charging systems tend to run higher voltages so the head unit may shut down if voltage goes too high. A Radio Shack 12V regulator (in-line with the stereo) will solve that problem if it becomes an issue.
ToyBoat5X
Thanks to everyone for your thoughts.
phatmanmike
ignition is powered directly and only from the battery. the stators ONLY job is to charge the battery, of course with help from mr.Rectifier. may just be only outboard able to run without the stator...is that even possible????
if your rectifier is shot, go see your pals at radio shack and ask for a 25 amp full wave bridge rectifier. works great on UN regulated systems, wich is what you got!
ricksrster
The two yellow wires from the stator are your charging wires. The blue, blue/white, red, and red/white wires from your stator power your ignition. They are your low speed and high speed windings. The brown, white and purple wires coming from under the flywheel are from the trigger.
ToyBoat5X
you guys are the best!
THanks
PuckHog
All the rectifier does is convert your alternator's AC output into DC. It's unregulated, so the voltage will vary depending on RPMs. You'll probably want to run a new wire (properly sized) from the battery to a regulator, then to your accessories as opposed to tying in at the controls or under the dash, unless your sure the stock wiring is of sufficient gauge.
