96 Suzuki 225 - What will cause no spark on the left side of the motor?
jimspitler
Are there any safety features that kill spark to the left 3 cylinders? Or is the CDI the only thing that can cause this problem?
deejaycee_2000
Re: 96 Suzuki 225 - What will cause no spark on the left side of the motor?
yes .... oil flow or water flow .... any warnings on your tach?
jimspitler
No warnings on the tach and everything seems to test right on start. They light up and buzz. Since it takes time to cause the problem and fixes itself when it cool for an extended period of time, I"ll check the water flow sensor first. Sound good? Can I unplug it or will I have to swap sides to see if the problem swaps?
Thanks a lot for the knowledge.
jimspitler
Actually, now there is no spark on the left side ever. Cold or after a couple of minutes of running. I can't find the water flow sensors on the motor or brownpoint.com. I disconnected the oil sensor and nothing changed.
http://store.brownspoint.com/dt225/2259000.asp
Here is the link. I can't find anything that is a right and left?
I'm at a loss???
jimspitler
ended up being the CDI and the stator.
thanks
