Tohatsu break-in & 4 hp - 6 hp carb upgrade?
jmoser
Finally got my Tohatsu 4 stroke 4 hp in the water, installed a Tiny-Tac and used 1-2 hrs a day of my vacation to break it in for the factory recommended 10 hr cycle. My only problem was idle adjustment; after the first 2-3 hrs it was dying at low idle, the adjustment screw is VERY finicky and I had trouble dialing it in better than +/- 50 RPM. I believe the hot (90+) temps and humidity did not help, by the end of the week temps had moderated to low-mid 80s and I had it dialed back in to spec.
Motor runs like a champ, by the 8-9 hr mark I was running it up to WOT for 1-2 min per spec; I hit the top end right on the nose +/- 150 RPM due to headwind/tailwind and related wave and current action.
Strongly recommend the TinyTac for any small engine or outboard, what a help to have real RPM readouts for break in and idle adjustment. I am going to semi-permanantly mount the Tach to the front of the motor housing.
Now - for the infamous 4 to 6 hp carb conversion:
I had purchased the jets and nozzle for the 6 hp carb spec, wanted to break in the motor before trying these out. I understand that the pilot jet may cause trouble due to the 'fixed air jet;' I studied the service manual carb diagram and am thinking this:
1) You should be able to change out only the main jet and nozzle, leaving the 4hp spec pilot jet in place. Pilot circuit usually dominates up to ~1/3 throttle, main jet dominates over 1/2 - 2/3 throttle. I see no reason why you cannot get the 6 hp top end from the main jet while leaving the 4 hp pilot jet in place [although there may be some issues in the 'transition' zone where the bigger main jet kicks in over the choked back pilot.] Another issue may be overreving due to prop pitch; a higher pitch prop may likewise struggle at low speeds with the smaller pilot jetting.
2) The 'fixed' jet is not really fixed - it is a mixture screw adjustment that is tamper-proofed via a pressed in soft metal plug. I have dealt with these on several motorcycle carbs, usually pretty easy to drill out the plug and pull it with a sheet metal screw or similar tapping tool. If I can get the plug out it should be simple trial and error to adjust the 'fixed' mixture to accomodate the larger pilot jet.
I need 1 more hr of top end break in and then I will try to experiment with the carb jetting. Spark plug color / fouling is a good indicator of low-mid speed mixture, top end RPM will validate main jet power improvements.
When time allows I will post results.
JOHNSROOKS
Re: Tohatsu break-in & 4 hp - 6 hp carb upgrade?
I too have a Tohatsu 4/5/6 2-stroke that I would love to upgrade. I like JMOSER's comments regarding the re-jetting and adjustment instead of the straight carb-swap.
My engine is the 5hp version. Does anyone have experience re-jetting this to the 6-hp spec.? If so, what were the issues, and how did it work-out?
This is a great engine in regards to weight and features; I just wish it had a touch more push...
Cheers!
hipster dufus
i was wondering if u had some pictures of ur tiny tach install? i too am looking at it for my 9.8. i think u could velcro it to ur motor housing. i dont want to look too mickey mouse. how hard was the tach to install?
JB
So you are going to increase output 50% by changing jets???
C'mon, JM, get serious.
Wee Hooker
You gents know this thread is closeing in on 3 years old, right???
JB
Ooops!! :)
