FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Does anybody see a problem with my bilge pump draining into the splashwell? There are to drain holes from the splashwell. Were planning to run bilge hose through the fuel line hole.
It will work in normal circumstances. The only potential issue I could see was if you took on a lot of water by burying the bow or a big wave, and the water exiting the deck was competing with the water exiting the bilge. Preferencial placement would be a through-hull.
Studlymandingo, I may have been incorrect in my terminology. What I called a splashwell is a raised area, almost like a tray, in the stern. My fuel tank and batt. is under it. I will try to post a pic. if possible.
Not sure if the pic worked but from what SBN said it should work fine. By the way if the pic worked, its not my boat it is just a similar one that I saved a lot of pictures from to aid in restoring mine.
You have to have a hosting site like photobucket(free). Upload your pics to there and them use the url they give you to post the picture. How did you post your avatar without a pic host?
That way doesn't work. You have to use a hosting site like photobucket.com, then use the little yellow button that looks like mountains in the back ground and paste in the URL that photobucket gives you.
That shouldn't be a problem considering that this is a low budget project boat that has horrible paint anyway. And if I was really worried about that I could run the hose all the way to the drain hole.
