denislajoie
- Joined
- May 28, 2005
- 62
ok sorry for the long post in advance but i ll try to explain the best i can. I have a older johnson 40 hp, older than 1967, its white, has a glass bulb on the fuel pump, and has 2 copper tubes for the water (apparently this help indetify it) its a manual shift it has no number plate or any munbers on the head or block, i also have a 1967 40 hp RK 29E i believe, electric shift, the first engine runs badly, only on one cylinder (top plug is cold after an hour on the lake) the 1967 runs excellent but the lower unit is screwed as all electric shifts are, can i swap the engine from the 67 onto the older body direct bolt on or will it not work cause of the shift linkage differences, or can i quickly or cheaply repair my older one, remember my time is worth nothing dollar wise and i have everything i need if they can bolt on so the cheapest solution possible, i dont mind spending money but only if i have to. thanks
