1955 FasTwin 15 hp turns over hard
Bruce N
I have an Evinrude 1955 FasTwin 15hp motor which is extremely difficult to turn over with the manual rewind starter. I am not weak! Turns over nicely with no plugs. I am using specified plugs J8C, so it is not plug/piston interference. Engine in trash barrel in water. Engine is in neutral. Any ideas?
TYVM
Bruce
AlanR
Re: 1955 FasTwin 15 hp turns over hard
Heres my advice.. LEAVE IT IN THE TRASH BARREL AND PUT IT AT THE CURB. Problem solved d:) When was the last time u used the motor because the piston could be sticking to the cyclinders.
Xcusme
Surely, you've got to be kidding , right???
If that's the case, PM me, I'll pay the shipping, no problem.....
tmcalavy
No comment on the second quote...only to say, lay off the sauce, it's too early yet.
Sounds like the shifter is in neutral but the lower unit ain't. If that's not the case, does the recoil work well all the time? No binding, etc.? Might want to run a compression test and put a light in the jug holes to see if there is something amiss in one of the jugs.
TYVM
Bruce
Bruce N
TYVM
Bruce
Got it running with combination of rope on flywheel and drill with socked on flywheel nut.
Puzzled why it so hard to turn over.
Where can I get unusual parts like the black rotating sleeve on the tiller arm?
Bruce N
Alan, tyvm for advice.
I DID get it to start. Removed rewind starter, ussed combination of rope and electric drill with socket on flywheel nut. Now have to set carburettor, etc.
However, I am puzzled why it should be so hard to turn over. Any ideas?
Bruce N
TYVM
Bruce
Paul Moir
OMC chart says use cooler J6C. Gap .030" Who's specification are you using?
If it turns over nice and smooth without the plugs in, the pistons can't be stuck or the lower unit froze up. But I will tell you it'll be hard to pull over that 19.94 CID engine when it's not actually mounted to the transom of a boat due to compression.
Check out NYMarine.ca for the grip. Many other parts are still being made. Ignition, water pump, etc.
Bruce N
Paul, thank you very much for the tip. I expect that mounting it on transom and the different angle at which I will consequently be pulling will make a huge difference. I found a small shop nearby for the non proprietary stuff for ignition, water pump, etc. They are really helpful. I will also try the source u mention.
This seems a nice motor.
Again thanks for the real help, unlike the other respondent who suggested junking it. I like old things. My wife is one. And so am I!
AlanR
What No body likes my adivce?
Bruce N
Alan, your advice is as good as your spelling. I think you meant "nobody," not "no body." "Nobody" means not any person at all, while "no body" means without a body.
I had hoped the presentation of my problem had made plain that the motor turned over with difficulty only with the plugs in. Paul I think hit it exactly.
Cheers,
Bruce
AlanR
Im sorry I dont have perfect grammer and spelling like your self. I only have my grade 10 and a LD I think im doing alright. I was only joken bud its a fine motor if its running.
bruce i have a '55 15 hp rude, love it. the most dependable engine in the stable. go to the engine faq forum and use joes reeves carb adjustments, mine no will idle all day, never a cough or sneeze, and loves wot. always starts 2nd pull.
imported_lorin
How about this. Maybe there's a lot of carbon build up on the pistons and cylinder head which results in higher compression than normal. Higher compression would make it harder to turn over with the plugs in but not with them out. Just a guess, but who knows with a 50 year old motor.
Bruce N
Bruce N
Cheers,
Bruce
Alan:
You exposed me! As I reread my response to you I realized that what I thought was humor was a stuffy retort. My apologies.
lorin has a good idea, it probably has never had a decarb. thats also in the engine faq forum.
