mbtskysurfer
Thread starter- Joined
- Aug 9, 2006
- 6
Guys (and Gals),
It is not often that I find myself with absolutely no clue what to do. Yet I find myself there with the Mercury on my Cape Horn.
Let me tell you what is happening and I will leave it to your very capable knowledge to help me get this thing running again.
This summer she gave me a problem not running over 2000rpm even at WOT. After much frustration and a lot of cussing I started to replace parts. As I am sure everybody with an outboard does in the beginning. I have replaced the spark plugs, fuel lines from the tank to the bulb and the bulb to the Tank/Oil Pump/Fuel Pump Tee. (Yes I took out the quick connect on the engine). This did not help at all. Next we tried the spark advance, put new switch packs. This helped. I got the boat to run at 5000 - 5500 with no problems for about 5 minutes. Then she would slip back to 2000 rpm and do nothing. I took her home and drained the whole gas tank by hand (150gal) what came out vaguely resembled gas. I replaced the fuel filter, filled it back up, and put StarBrite in the tank.
It was great! She would do what ever I wanted. Took her out on three full day trips. I had finally licked my problems. I was a happy boat owner.
However.... (it seems there is always a however)
Two weeks ago I put the boat in the water to go check my crab traps, like I had done three days before. She started normally. I got out past the "No Wake" area and took her up to WOT. She climbed as normal up to 4500 - 5000rpm and died. I don't mean died back to 2000rpm. I mean she died completely. She would not start at all. I had to be towed in. I took her back to the house and the next day I began working on it. After almost 30 minutes of turning it over. I finally got her to start, I did this by holding down the Fuel Enrich valve and holding full throttle. Once it fired I kept holding the fuel enrich valve and kept the full throttle applied. It acted like it was struggling, spitting and sputtering. About two minutes of rough running, it cleaned up and worked fine. I stopped and restarted it a number of times with out any problem. Ran it for about 20 minutes.
I figured that I had a problem with water in the fuel. I installed a fuel separator and a new fuel filter.
Yesterday I took her out again. To check the traps, which at this point have been in the water for two weeks. Same thing. And I mean exact thing. The boat even died in the same place in the water. Same story. Got past the "No wake" and went to WOT. She ran all the way to 4500 - 5000rpm and died. Took her home and was able to get it running again. I looked at the fuel system there is no problem with delivery to the carbs. I looked at the coil packs and the switch packs. Noting is disconnected or obviously damaged.
To get her running again, it took some WD-40. (Yes I know it is bad) She fired erratically, then I get her running steady again, and like before it spat and sputtered. In about 2 minutes it cleared up.
I am sorry about the length of this post, I figure the more info that I can give you will help. I am lost. I have no idea what to next.
I welcome any advice on what to try. And if you are in the Pensacola/Perdido Key area and would like to make some extra cash I am more than willing to pay a qualified mechanic to come to my house and take a look at her.
Thanks so much I eagerly await your replies.
Matthew Simmons
Matthew Simmons
