Re: 1990 OMC 4.3 quits after moderate use.
It doesn't make sense to me that I would lose spark at night and then have it again in the morning without doing any thing to the engine.
Trust me, it happens all the time. It's not a night and day thing, it's all about heat. Coils can go bad with heat and work fine when cold, ignition parts are the same, connections with a little corrosion buildup more resistance with heat.
Also sounds like your boat may be lacking in some maintenance if you can't even get to the distributor cap. When was it last tuned up?
I'm not saying it's not a fuel problem, just saying it's a possibility. When it stops, your first job in tracking down the problem is to find out if you are loosing spark or fuel.
Without that information you are going to be tinkering and hoping you find a cause of some kind.
