Re: 100 hp evinrude trouble starting
You probably won't see any fuel going in while it's just spinning over. Lets start at the beginning. Explain your starting proceedure. Now, assuming the motor has timed spark, compression and the carbs are OK here's what's worked for us --
1- Prime the fuel system by pumping the bulb until firm. This will fill the carb bowls and also send fuel to the primer.
2- Turn the key to "On" but do not engage the starter.
3- Push the key in for an 8 count (or so). This opens the primer and allows the fuel thats under pressure to be released into the intake area.
4- With the throttle in a fast idle position, turn the key to "Start" to engage the starter. The motor should start almost instantly.
You may have to bump the primer a time or two until the motor warms up.
Oh yeah, we're also assuming that there's gas in the tank and the fuel line is connected. d
