I have a 97 rinker viesta vee 266 , replaced the tired 350 merc 2 bbl motor with a 383 mpi motor new from mercrusier. I had a fuel problem that I thought that I had solved by removing the anti siphon valve. afterwards, the boat ran great, until a 1/2 tank then began to starve above 4000 rpm.
I drained the tank today, thinking it was bad gas.
afterwards, i attempted to unhook the vent line from the tank in an attempt to blow it out, in case it had become clogged. when i put air pressure to the vent hose, while unhooked from the tank, it blew back out from the vent fitting on the tank. after some looking up under the deck, and tracing the vent line back to origin, it connects to the fuel filler neck at the back of the boat. This system has no way to vent itself, as the gas cap seals tight!!!! any suggestions? this was the way this was built at the factory, would you reinstall an outside vent, or add a electric fuel pump? the boat runs great when full, but after about 20 gals develops a starvation at above 4000 rpm or upon acceleration
thanks ,, any help would be appreciated...
this is a fuel injected motor, replacing a carb motor
hud
hud
