Re: Flywheel Pulling Bolt Size 71 Johnsn 60hp
Got the flywheel off with what I had, only screwed em in about 1/4", but they weren't the right size I could tell, but the flywheel came off damn easy with a sweet *POP*.
I'll get a set of 5/16-24 tomorrow and see if I did much damage to the threads from using the 18's.
Points were bad pitted, could not see spark on either. Took the points off and emory boarded em and stuck em back in, now sparks on 1 set (the far set in the series) turning the flywheel nut with a socket but no sign of spark from the other.
It can't be a ground problem because the far set sparks, so looks like I'm picking up a set of points tomorrow from the marine store. and a condenser too I guess.
Thanks for all the help guys! I smell Ignition sometime tomorrow!
Carl
