I have an ongoing problem. I have a 93 johnson v4 90 hp ,on a 18 foot four winns bowrider. I can drive around at full speed, it does fine. I can pull my son on a wake board and it does fine. When I put the big tube on the back, the horn goes off, solid sound. I shut it down and wait a wile, try again, then the same thing happens. The sticker on the side of the boat says, solid horn is fuel restriction. Over the last months I have changed the fuel filters changed a piece of hose I thought could have been kinked. Any ideas? could it be cloged injectors? If so can you use injector cleaner with the oil mixed fuel.Thanks, Ron
