clint
Thread starter- Joined
- Jul 11, 2006
- 157
Last week I ran my 1979 140 evinrude, rebuilt in 1998 and it wouldnt plane over 3000 rpm's. I changed head gasket and found it wasnt blown. Reinstalled head and took compression test. Left bank has 125 on both cylinders. Right bank top had 110 and bottom 125. Rebuilt carbs, fuel pump is new, checked all fuel lines. I changed all spark plug wires. I took my 140 evinrude for a ride today. It started out of channel at full normal power of 5500 rpm's, which I havent felt in a long time. Dropped throttle down to 4500 rpms and cruised for 5 minutes temperture was normal. After 5 minutes it dropped down to 3000 and wouldnt go any higher? Got it home and left bank bottom cylinder spark plug was clean as previous run which indicated maybe water getting in cylinder. Now I know that cylinder had to stop firing and fuel cleaned it off when it wasnt firing. At idle in test tank after 10 minutes its a brown normal firing color. Could it be a coil or powerpack? Do powerpacks go bad in just one cylinder and not effect the firing of the other? Could it be just a bad coil after it gets hot, stops giving out voltage? Need all the input, (HELP):'( I can get. Thank You!:%
