1993 4.3 OMC
My ESA system is currently not working. I checked it by running the engine and manually clicking the micro-switch that is attached to the shift linkage. Doesnt drop the RPM so I was going to replace it. But I want to make sure I am replacing the right part. Do I need to replace the micro switch that is attached to the shift linkage only? Or do I also need to switch out the shift assist module (little black box with the five wires coming out). Or both....
Just wanted to get some advice or troubleshooting direction before I start throwing parts at it. Thank you.
