Knocking over 1500 rpm in gear only
beach
When in gear motor starts knocking about 1500 rpm, started knocking lightly and got louder last time out to where I haven't had it above idle again. Below that no knock. Out of gear can run it up to 3000 rpm smooth, no knocking. Any ideas? Could it be bad spark in 1 cyl or a carb needing cleaning?
1974 Mercury 850
1 152 psi
2 150 psi
3 151 psi
4 152 psi
lilmandavis
Re: Knocking over 1500 rpm in gear only
shift adjustment? is it doin it under load? only in gear or in neutral to?
beach
Knocking only in gear.
lilmandavis
figure out what part is knocking. the power head or the lower unit.
gungalunge
I walked away from my engine idleing off the dock it was sounding good . when i heard it in gear i knew going 3500 rpm it was disapointing . now i am rebuiling the lower end extensively , hope to see good results ..
beach
Seems to be comming from the top end. It starts knocking at 1500, if I try to increase rpm it starts shaking/vibrating so bad it wont run.
beach
I think the gears may be slipping or jumping out of place when I try to accelerate.
I took it out today and opened the throttle up, it started clanging as usual but when the motor got up around 3000+ the noise stopped and we weren't going anywhere.
What year and hp range can I look for a used lower end?
roger3645
beach e-mail me at rip3645@hotmail.com I may have all the parts you need. I run a 1975 and 1973 merc 850, I have extra LU parts. I'll check them out this weekend.
