1975 Johnson 6hp SeaHorse 6R75R intermitently looses power - ?disapearing spark
morda77
Hello to everybody,
Here's problemo: 75% of running time loses power. sometimes goes OK but then goes back to low power again. almost impossible to run on lower RPMs and will shuts off after 10-15 seconds of idling. if you wil add throtle it'll goes on again.
probable diagnosis is intermittent spark in lower cylinder.
because when it loses power I can remove lower spark plug end and get same runnig without any changes.
as soon I remove upper spark plug end ( with lower one in place) engine shuts off instantly.
I have carb cleaned, brand new spark plugs, brand new spark plugs ends, brand new fuel with right mixture,
any sugestions would be very appreciated. since I am on the budget and can not afford to go to the dealer please email me or post what would you do if that would be yours case.
Thank you.
Denis.
morda77@mail.ru
Xcusme
Re: 1975 Johnson 6hp SeaHorse 6R75R intermitently looses power - ?disapearing sp
Denis, Welcome to iboats.
Your motor has a simple magneto ignition system. Your next move is to find out why your losing spark. You'll have to remove the flywheel and inspect the coils, points and condensers. Look for cracks in the coils and check the points gap setting (.020). The good news is that the parts are cheap and available. If you plan on working on your motor, a service manual is a must. It will show you how to perform all service routines.
morda77
Hello everybody.
Thanks to Xcusme: You were right.
as soon I took out the flywheel first thing I see is contact point for lower cylinder has no gap at all. Futher inspecting coils I found huge cracks in both of them.
took one which belongs to lower cylinder and see on bottom side big hole - dark and burned plastic. defenetly there is a problem here.
will be shoping for parts today.
what I've found for parts number so far is below:
* Ignition Coils: Sierra P# - 18-5181
* Spark Plug ends: Sierra P# - 18-5750
* Contact Point set: Sierra P# - 18-5156
* Condenser: Sierra P# - 18-5199
* Tune up kit: (two condenser and two contact points): Sierra P# - 18-5006
I would appreciate any input on this case.
in return will keep you posted.
Also someone know good parts retailer in Toronto area with reasonable prices please email me.
Thank you. and have a nice day.
Denis.
Xcusme
When you replace the parts,work on only one cylinders ignition parts, at a time. If you get lost with the connections, just refer to the untouched side.
Mount new coil, and pay attention to the mounting base bosses. Surface A must be flush with surface B.
To adjust point gap, rotate crank shaft and align crank shaft keyway with the points rub block. Set point gap to .020.
morda77
Hello to everyone,
First I want to thank everybody for keeping this message board. Afterr all it was only one source which helped me to fix my motor.
Motor is working like charm now and I want to share accumulated knowledge with all "first time" guys like myself.
about parts:
1) I ended up buying pair of QuickSilver ignition coils Part#: 802371A 1
they were $31 each (+taxes)
2) I bought 6 feet of new ignition wire (after job done only 10 inches left) = $1 per foot.
3) Original OEM OMC Tune up kit Part#: 172522
was $25 (+taxes)
I have to say that I have ordered and had on hands
Sierra TuneUp kit #18-5006.... BUT never used it and didnt even opened the package because when I got it first thing you see is the poor quality of materials and assebly of contact points, and I've decided that it's is worth to go ahead with OEM TuneUp kit. Beside that difference in price was only $2 (TWO) !!! bucks.
Here I would like to start from begining:
1) To remove the flywheel you WILL need a "HARMONIC BALANCER PULLER" anythig else will not work and you can damage the flywheel. I will probably have to stop by
closest hardware store to get bolts of apropriate size which fits holes (three of them) on the flywheel.
dont be cheap go and get this puller . it costs only 20bucks and you will need it not once in your life that's for sure. especially if you do not have a service manual like me. ( I had to take the flywheel off about ten times to get points properly adjusted)
2) since you have you flywheel off the shaft it is a good idea to take a coupe of pictures for the records just in case. then as mr. Xcusme sugested it is best to " work on only one cylinders ignition parts, at a time. If you get lost with the connections, just refer to the untouched side."
inspect the coils : I can bet you'll see cracks and burned holes.
From my experience it was relatively easy to mount all new part including new ignition wires in place.
BUT incorrect setting of poins gaps cost me skiping of this weekend fishing.
You obviously don't want to repeat my mistakes so another good advise from mr.Xcusme - " GET THE SERVICE MANUAL"
I had to spent whole sunday to set the gap "in blind"
even thoug it sounds easy " To adjust point gap, rotate crank shaft and align crank shaft keyway with the points rub block. Set point gap to .020 "
for this particular motor it isn't quite true.
you probably noticed marks on top of the flywheel 'set points 0.020" and there are marks on side of the flywheel
"set points T" and "set points B" and correspondind double line marks on the base of ignition system....
Thinking about "how the heck this thing works" will make your mind to boil...after taking off the flywheel for the fifth time ...get the manual...only one thing I can say
here.
But taking in consideration that I still don't have the manual. makes me think it's doable or it's just my luck :))
Main problem while setting the points gap is that you can allign marks on the wlywheel "set points T or B" with the lines on the ignition system base. and adjust points but nobody at any message board mentions in which position THROTTLE handle should be when you're making your adjustments. It is Important. (here's disscution wellcomed)
I will describe procedure which lead me to success. Though I cannot guarantee it is by the manual.
* disconnect spark plugs wires and remove spark plugs.
* Turn Throttle handle to START.
* allign marks on the wlywheel "set points T" with the two marking lines on the ignition system base so flywheel tooth is between those two lines.
* take the fly wheel off
* you'll see on the crank shaft base stamped mark "TOP" then space and then some numbers stamped.
* rotate Throttle handle so points rub is on the letter "o" of word "TOP"
* at this moment you can set corresponding points gap to
0.020.
* put the flywheel back on.
* rotate clockwise and allign marks on the wlywheel "set points B" with the two marking lines on the ignition system base so flywheel tooth is between those two lines.
* again rotate Throttle handle so points rub is on the letter "o" of word "TOP"
* at this moment you can set another corresponding points gap to 0.020.
* put the flywheel back on, but do not put the nut On it yet.
* With spark plug removed and held tight against block with wire on it, you should be able to spin flywheel by hand and see a spark at electrode of plug.
No spark - recheck your work.
you should see spark for both cylinders = for both wires.
* after this retighten flywheel and now you can try to start
and check your motor.
just for example of what improper gap can give you I'll list what I had while making my way.
1) no spark at lower cylinder ( even though ALLl parts were replaced on new)
2) runs ok at iddle speed but chockes dead as soon as you add more throttle.
3) runs ok at fast speed but dies on low RPMs.
it's all was because of improper gap.
I hope this posting was in any helpl for somebody out there.
Thanks again for guys who keeps this forum up and running and I hope you'll get your motor fixed.
Denis.
morda77@mail.ru
