Re: steering yoke loose
i think i know what you are talking about....
just to check; are you talking about where the steering fork connects to the steering arm inside the boat? it connects to like a pitman arm?
if that is the case i just had that same problem. the bolt that is made to tighten up that "pitman arm" is not strong enought to do the job. after i broke the bolt i swapped it out for a grade 8 bolt and that still wasnt enough. once i realized that the "pitman arm" was tapered on the inside, i decided to take it to a machine shop and have them squeeze the hole more closed. it took three tries at the machine shop (2 tons, 4 tons, and finally 10 tons)to get it tight enough. when i got back home i pushed the spline of the fork back up into the pitman arm, and it stayed
did that make sense??
