boatingbob
- Joined
- Aug 1, 2006
- 88
is my motor too low?
I've been having handling issues.
boatingbob said:is my motor too low?
jtexas said:boat pulls to starboard, loosen the trim tab above the propeller, turn it a degree or two to starboard and retighten.
I was told by my local boat shop that it should be 1 inch higher then the bottom and race boats have thiers upto 6 inches above the bottom.wormboy said:I had read in other posts in the other (non-engine repair) forum that the cavitation plate should be about even with the bottom of the hull-- don't know if this is always true, but yours is certainy lower than that.
Paul said:That's the exhaust outlet/water inlet not a trim tab.
On older non-thru-hub OMC motors the anti-ventilation plate is normally set low, lower than the hull. This will not result in handling issues. Which motor is this anyway?
