gelcoat cleanup
jesters420
I seem to have got some spots on the gelcoat with poly resin. The surface of the gelcoat still needs to be cut and buffed. What should i use to take the resin off without getting to deep into the gelcoat?
bjcsc
Re: gelcoat cleanup
I don't know if that's even possible. In my limited experience, new gelcoat is very sensitive to solvents, esp. acetone. Your best bet is probably block sanding it off, repairing the gelcoat.
jesters420
Re: gelcoat cleanup
It is not new gelcoat it is 34 years old but the paint and hull are in great shape. I just don't want to cut to deep into the gelcoat as I bring it back to new.
bjcsc
Re: gelcoat cleanup
Sorry, I assumed by the "needs to be cut and buffed" that it was a new surface. You could try to chip the resin off with a plastic scraper/putty knife, but if it has a good grip, careful block sanding is what I would do...
jesters420
Re: gelcoat cleanup
Thanks for the help. I will see how easily it will chip of the surface.
Tail_Gunner
Re: gelcoat cleanup
Gel coat is not fine china, just take 80 grit,sand off the epoxy,polish the gel and get on with life.........8)
