tampa boater
Thread starter- Joined
- Aug 20, 2006
- 22
Greetings!
I have E225FPXSSC 2000 225 Ficht Ram which has FICHT Fuel Circulation Pump P/N 439712 and need to replace. (Voltage for 10 seconds at the pump when key turned to ON but no pump noise and no pressure at fuel rail) Does anyone know if it is interchangeable with newer P/N 5004429? I found a used 5004429. Please see part diagrams below from BRP's website.
Looks like most of the mounting hardware is same (based on P/Ns) but the fuel feed and return manifold assemblies appear different in the newer 2002 model.
My biggest question is If i can get it to mount up to the hoses, does it have the same fuel pressure / flow specs?
Thanks!
Thanks!
