Texasmark
- Joined
- Dec 20, 2005
- 15,009
Re: Performance of two boats different shafts..
I agree with steel. You may be mistaking plowing for just john attitude. That boat is going to run flat on the water once on plane and it should plane at 15 mph . You have a very very wide beam and a long length. With the whole boat (except for a little v in the front) in the water, the whole boat will try to steer it'self. Also it probably has a predominant center "keel" running full length which will insure that the boat does the steering for you.
Yes the transom has a pretty steep angle but I don't see triming having much, if any effect on the performance of this boat; the bottom is just too big and too flat.
I think you are expecting something this hull can't give you.
My 2c,
Mark
My 2c,
Mark
