Mercruiser pre alpha(?) upper/lower interchangeability
mbjeeper
I recently bought a '79 Sea Ray with A Mercruiser 470, and within a short time the upper ring & pinion destroyed itself. The lower unit looks OK, so I am going to try to find a used or reconditioned upper, as I don't have the tools to set up the gears myself. Also, the sterndrive is not the one the boat came with, I was told by the prior owner.
My questions are about interchangeability. My upper gear tooth count was 24/24, which should make it a 1.65 ratio.My unit has the lifting eye cast on the top cover, which I am reading is a pre-alpha drive. It looks as though there were 2 pre alpha drives, an R and an MR. How can I determine which I have?
Also, as I look for a replacement upper unit, what will fit?
I have seen suggestions that anything 1983 or older will bolt onto my lower and gimbal housing, but of course I want to be sure. The only things that appear to be bad in my unit are the gears themselves, so i could still use my joints and shafts if I need them. It looks as though there was a difference in shaft length on some units. Are there any interchangeability issues that I need to know about?
Will later model upper units work?
I would like to get this boat back in the drink before it gets too cold this fall.Any help appreciated.
Thanks,
Greg
mbjeeper@aol.com
Bt Doctur
Re: Mercruiser pre alpha(?) upper/lower interchangeability
the 1.65 was used on inline 6`s ,i think the ratio for the 470 was 1.85.
Haut Medoc
I'm pretty sure Bt Docktur is right....
What part of Jersey, btw, BD?
Anyway, why don't you post up that serial # located on the engine by the heat exchanger or go to the Merc. site with the # & find out for sure.....
Also, if you shattered the gears as you say, then you probably have debris in the lower, (they are connected)..
The lower should be disassembled, cleaned & resealed at the very least....
I would hate to see you replace the upper & then have garbage from the old lower trash 'em both, JMHO.....
Ebay has aftermarket drives by SEI for A around $1300, not sure about shipping to UK, though......JK
Bt Doctur
near exit 9 NJTP
Haut Medoc
Raritan River, eh?
