best way to lift a force engine?
Kajun37
i need to to figure a way to lift a engine without having someone to help me...... i have a garage with strong rafters...was thinking about using a "come along" or some type of pulley with cargo straps on the engine..think this will work? i dont have the lifting adapter thing that connects to the flywheel.
what do ya'll use?
roscoe
Re: best way to lift a force engine?
Do you want to lift the motor off the boat?
And put it on what?
Or do you want to lift the motor and put it on the boat?
The problem with straps is that the most secure place to put them will put them in the way when you try to lower the motor back down.
Kajun37
i need to lift a 85 hp motor to put on a stand......then i need to lift my 120hp off my boat to change the lower shock mount then put it back on boat.
AlanR
i use brute force and 4 buddys
roscoe
Old fashion block and tackle will work for you.
Most come alongs only work in one direction. So you can lift it up, but can't lower it back down slowly.
ewbish
what do ya'll use?
Get a rope big game hoist from Wally World or Cabellas, only 15 bucks. It'll hoist an outboard no problem, trust me on that, I've hoisted 1200lb elk with them. Does your powerhead have a lift ring?
Kajun37
dang roscoe...i didnt think about the letting it down slowly part...i just ordered a come along :( i'm gonna run to northen tools and get a pulley hoist....thanks
boatsmitty
what do ya'll use?
boatsmitty
I bought a lifting eye from Force that screws on the top of the shaft and use a chain hoist off the rafters.
boatsmitty
I bought a lifting eye from Force that screws onto the top of the shaft and use a chain hoist off the rafters.
tiller7104
Just a quick thought because of the weather conditions here i remove my 85hp almost every year.....I use a ratchet strap with every thing loose I get it tight enough that it almost lifts off of the transom....then I let the air out of the trailer tires it gives you about an inch more than you need......when replaceing it I position the motor and reinflat the tires...I do it myself! Just a thought...I hope this was helpful.
cougar1985
come alongs lift up and down. i raised and lowerwd my 320lb evinrude several times with mine.you can lower the motor a inch or less at a time with a come along.i also used the rafter trick.
Kajun37
well went and bought a cheap 2000lb pulley at northen tools..it lifted it fine but i had to call a buddy over to postition motor on stand as i lowered it.
