Boat is a 1971 . Engine is a 1974 Mercruiser 165. A pre Alpha "R" drive is bolted up on back. A whining noise coming from the outdrive occurs between 1000 and 1200 rpm and in forward gear only . Does not occur any other rpm range. Tilt or trim does not appear to affect it. The noise does not occur in neatral at any rpm. This is happening with the boat in water . Drive was filled with lube 3 weeks ago and went in the water 2 weeks ago. What is causing this noise? Would low gear lube make noise all the time? I don't see any gear lube or oil in the water outside the boat. So it doesn't appear to be leaking outside the bellows at least. What do you guys think?
