40 hp VRO WOT?
tiller7104
Hey all, I am reproping my boat and I know I need to know the ideal WOT before I start so I know where I should be !! My boat is an 18 ft. Aluminum Deep V Sea Nymph with all the bells and whistles so it is heavy. I didcussed this abit in the incorrect forum so I am presenting it to you guys.
The boat now has a 11 3/4 X 17 on it now
I have a 12.5 X 13 sitting in my boat as a spare
I was told that the 12.5 X 13 will give me a better hole shot ! ( BY Steelespike) I am not setting any land speed records with this boat nor do I need to..... in the same respect I do not need to pull a bardge with it either, so in you opinions which do I use or do I need something else?
Again what should WOT be? Thanks in advance ! Stuart
rickdb1boat
Re: 40 hp VRO WOT?
Believe that's your 1989 40 HP you're talkin' about. If so, look for 5500-5700 RPM's at WOT...An 18'er with a 17" pitch seems steep. I'd try the 13 and see what RPM's you get....
tiller7104
Re: 40 hp VRO WOT?
It is my 1989....sorry and wow I am lucky to get 4000 with the 17 now, does this sound like I have an engine problem or do you think it is the 17 pitch prop? Hummm I may have been running off kilter for a while??? What do you think?
Re: 40 hp VRO WOT?
A 17 pitch prop is too high for that combination. You are lugging the engine seriously which is really a bad situation. I had a 40 Evinrude on a similar size boat and the engine really labored. It was happier with a 15. I tried a 13P stainless and it simply reved too high (6000). The proper prop would be 11-3/4 x 15 in my view. These are available all over as they are a fairly standard size. In fact if you are interested, I have a 11/3/4 x 15 aluminum in excellent shape. Email me at DBLSI@charter.net if interested.
tiller7104
Re: 40 hp VRO WOT?
Thank you very much for the imput,,,I am going to put the 13 on this week, but I am going to email you in ref. to the 15.....it has always seemed as if it ran a bit drug down.....well I think you guys have me on the right track,,,,again thank you I will certainly let you guys know...for a better Idea i am posting my reseration on the restoration section check it out and let me know!
