brother chris
- Joined
- Jul 28, 2002
- 2,063
My motor overheating alarm has been going off once I start it and run it for about 2 minutes.
So, to diagnose the problem, since I installed a new impellor and thermostat last year; I took the thermostat off and tested it. It opened at 145 degrees, so the thermostat is fine. I also started the motor without the thermostat and the overheating alarm did not go off.
So, I went and started the motor(after re-installing the thermostat) and after a couple minutes, I could not put my hand on the motor, it was too hot!:^ And the overheating alarm did not go off.
If I have a good P-stream and the thermostat works properly and the impellor is fine, then why would it overheat?
Any ideas would be much appreciated. I want to go boating tomorrow, so hopefully I can figure this out tonight.
Thanks,
B.C.
Thanks,
B.C.
