what does fogging motor mean
MH7142
ive looked at a couple motor and the owner says that he had them fogged before putting them up is this good or bad and what is it thanks mitch
Bob_VT
Re: what does fogging motor mean
Fogging is accomplished by using Fogging Oil. Most hardware stores and motorcycle shops carry it.
Essentially it is spraying oil into the spark plug holes turn the engine over a few times and spray agiain and re-install plugs. It puts an oil coat on the surfaces to prevent rust, corrosion and things siezing up during storage.
Read the WINTERIZING post in the Eninge FAQ section and apply what sections are needed. It outlines alot about I/O drives but, basically the same applies to all engines.
Texasmark
Sea Foam, in the spray can called Deep Creep, is designed specifically for that purpose. And spray some in the carb air intake also.
Mark
MH7142
thanks for info that helps to clear that up mitch
